| | | Forums66 Topics128,162 Posts1,056,943 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30492 05/26/2002 4:11 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I'm just starting on a 1942 1.5 ton Chevrolet 4x4 military truck with a PTO dump box. There is air in the brake lines. I plan to use a pressure pot and bleed through the master cylinder with a special adapter. Question is: should I back off the adjusters before bleeding? My partner in this rig thinks there could be a problem that could result in the shoes not being able to retract. I assume this has the huck brakes, but don't have a Manual covering this truck to research it. There is a hydrovac booster to contend with too. Thanks for any ideas. This truck is so ugly it's a real beauty as well as a good soldier. :confused: | | |
#30493 05/26/2002 5:12 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | The basic service on these is to tighten the brakes until the shoes start to drag and then back off 4(four) notches. and then bleed. do this on all wheels. ps I almost forgot- If you have the "stud adjuster"- turn till shoes drag and back off 3/4 turn.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#30494 05/26/2002 7:05 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Does this truck have two adjuster slots on each backing plate ?? Those huck adjusters have to go clockwise to push the shoe out against the drum. Clockwise as you look at the outside of each end of the wheel cylinder. It will feel as if they are going in two different directions because you look at one end of the cylinder from the front and the other from the rear.
If you back off the adjusters, that will make the retraction distance longer, not shorter. I would adjust them properly , then bleed..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#30495 05/26/2002 9:07 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Thanks for the advice. We are trying a "rolling restore" on this to get it movin' off the former owners land without towing. It's a lot easier to sneak them home when they can get there on their own. As the trucks have come home, it's getting harder to jockey trailers and tow dollies here on the hill.  | | |
#30496 05/28/2002 8:45 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Put it in low range,,,,, you won`t need any brakes!
#30497 05/29/2002 12:55 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Tag it, insure it, and get tow insurance. Then call the wrecker and turn it in on the insurance. :p
Fred 52 3600 69 C-10
#30498 05/29/2002 3:06 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Luke and Fred are both right. I don't have the exact numbers yet for the axles and transfer case yet, but from the size of those Pumpkins its gotta be a stump puller. Got those tractor tires, and duals on the rear. Think the dump box capacity must be about four yards.  | | |
#30499 06/02/2002 3:47 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Just an update. We hooked up the pressure pot bleeder to the m.c. at the cap. No go. Pulled the m.c. had a stuck piston, old fluid had turned into jello. Will this be the same in the hydrovac too? We have not pulled that yet. Hoses will probably have to be replaced, don't know about the wheel cylinders but pistons and cups seem to also be froze. Good news is we got it running with all valves going up and down.  | | |
