8 members (cmayna, 46 Texaco, UtahYork, TUTS 59, jmoore, EchoBravoSierra, Otto Skorzeny, TexasA&M48Truck),
87
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | I think I've heard (or read) that some roller rockers (1.75s I think) will work under the taller MM valve cover *IF* you grind down the outer ends of the #1 and #6 exhaust rockers. Is this true?
Thanks! -ftyler | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | You plan on spending close to three bucks on a set of rollers and then grind the corners off?????? You and Ken were talking about rollers awhile back. He was going to go for the stainless Crowers because he thought they might fit inside the stock type cover. Maybe he'll let us know how that's coming along. I decided to use the Crane Gold Rockers. I couldn't stop myself. I had no plans of using a chrome or aluminum cover so that was no problem. I made a cut on the pass side of the cover from the top down about 3/4 of the way. Folding that forward squared off the front of the cover and left a 1/2 wide gap on the side. I did a little hammer work and welded a filler strip. I stayed about a 1/2 inch away from the gasket area. I then did the same on the other end. The height isn't a problem. The evening I put the head on, I just had to see what this thing was going to look like with the rockers on. Take note, there is not one nut holding anything on. There are studs front to back for the manifolds. One other very important thing. I had to take .025" off the stud bosses to clear the bottom of the rockers.
[img]http://home.earthlink.net/~satalite/Engine.jpg[/img]
'67 GMC 3/4 292 4spd
| | | | | Joined: May 2003 Posts: 57 Member | | Member Joined: May 2003 Posts: 57 | Nice looking unit! What is the booster/mc out of? Looks as if original.Tidy. Keep it up!Tom
65 C10 292/700R4 long fleet...Gettin closer by the day.
| | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | - Truck is '67
- Disk brakes are '77
- P-steer is '77
- MC and booster is '87 S-10
