4 members (Hotrod Lincoln, Ranger, Peggy M, carbking), 44 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#30115 02/04/2005 8:57 PM
Apprentice
Apprentice
put new cam,timing gear ,amd points in the 54
starts easy and runs fine,but when warm the starter drags a couple times then cranks good but dosen;t start
it will roll and start when hot so where should Ilook
If it were an old 216 i WOULD BE THINKING VAPOR LOCK BUT ITs NOT
#30116 02/04/2005 9:37 PM
lutrexen!
Check your battery cables. Make sure they are 'big' ones if you're running 6 volts. Connect your ground to the starter mounting bolt and make sure all connections are clean. Had the same problem and after making up new cables the problem was solved. Others on here have said the same thing.
George
#30117 02/04/2005 10:34 PM
Double check your dwell and timing (and plug gap), that is usually the first culprit in having warm starting problems. Often point gap isn't enough because the relationship between it and dwell changes as the distributor wears.
Another likely culprit is that your valves are set too tight, and the lash goes away when the engine is warm, hurting compression at low speed.
Also check the idle mixture and the carb for leakage. Air horn gasket leakage to the inside can cause rich idle and intermittant mixture problems that make warm starting tough.
Also, check for vacuum leaks. Usually hard warm starting is an ignition problem on 235's, though.
Paint & Body Shop moderator
