1 members (Peggy M),
105
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30081 07/19/2003 11:35 PM | Joined: Feb 2000 Posts: 12 Junior Member | | Junior Member Joined: Feb 2000 Posts: 12 | I have a 57 Chevy with a 3spd OD transmission. Today when starting out I heard a load pop and then the trans. shifted normally. The next time I stopped and then started again, there were no forward gears, only reverse. After putting it in reverse briefly, the forward gears worked normally and I traveled for several miles. When downshifting to 2nd around a corner, I again lost the forward gears and had to be towed home. Can anyone give me an idea of what this problem may be before I tear into the transmission? I have a spare 3spd for parts. Also,if anyone could recommend a vendor for repair parts I would appreciate it. Thanks for all suggestions. | | |
#30082 07/20/2003 2:06 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Joe,
Sounds like the overrunning clutch in the overdrive unit. It's locked out in reverse. Does it do it with the overdrive handle pulled out?
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#30083 07/20/2003 6:01 AM | Joined: Feb 2000 Posts: 12 Junior Member | | Junior Member Joined: Feb 2000 Posts: 12 | OlBlue, You're exactly right. After my initial post,it occurred to me that I forgot to check it with the OD lockout cable pulled out. I checked it and it works fine with the cable pulled out,so I figure it is the freewheeling clutch mechanism. If anyone has any tips for this repair or a source for parts I would appreciate it. Thanks! | | |
