1 members (porsche),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30035 07/31/2003 7:32 PM | Joined: Apr 2001 Posts: 43 Member | | Member Joined: Apr 2001 Posts: 43 | While cleaning up my rear axle I found a hole. There is a hole in the top of the axle on the drivers side. Is this a vent? Should I just leave it alone or should there be a tube attached? Or should it be plugged? It is threaded. My truck is a 48 1/2 chevy TIA | | |
#30036 07/31/2003 8:02 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There should be a vent there. It is a pipe nipple with a piece of sheet metal crimped over the end, keeps the dirt and water out. If the hole is plugged, you will blow out the axle seals when the oil gets hot.
I learned that the vent on my 69 uses a piece of rubber tube that is attached to a crossmember and ends near the bed, but it has the same function.
Fred 52 3600 69 C-10
#30037 07/31/2003 8:45 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I just lost mine,. The threads in the hole were not in good shape. I found a replacement, retapped the hole with a 1/8 pipe thread tap and threaded in the new one... I added some Locktite as well..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#30038 07/31/2003 9:05 PM | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | I still have the vent and cap on my (newly) cleaned rear axle. Can I just carefully pry off the sheet metal cap that is crimped on to remove and clean the vent and then crimp the cap back on?
Thanks.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
#30039 07/31/2003 9:07 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | ttt8,
I think that the axle vent hollow bolt also secures the brass brake line junction block to the axle tube....
(Might have this confused with another vehicle, but most cars/trucks vented their axles this way.)
Should be a gizmo that looks like an 1/8" pipe nipple with a thing hex on it for a wrench, more nipple, then a little cap crimped on top, loose enough to vent, but tight enough not to come off. The vent hose deal came along in the '60s.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#30040 07/31/2003 9:25 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | The vent on a 48 Chevy stands alone, it is not attached to a brake junction block..
#30041 07/31/2003 10:38 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The hose which goes up to the frame helps keep water out if you happen to go through deep water. We had to install lines from the vent fitting on the axle housing up to the upper part of the firewall on a few fleets of trucks(per company request) Couldn`t hurt to add a little length Tony M
#30042 08/01/2003 1:55 PM | Joined: Apr 2001 Posts: 43 Member | | Member Joined: Apr 2001 Posts: 43 | Can someone please post a picture? This might help me when looking for an original. TIA | | |
#30043 08/01/2003 3:15 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by Jeff Nelson: I still have the vent and cap on my (newly) cleaned rear axle. Can I just carefully pry off the sheet metal cap that is crimped on to remove and clean the vent and then crimp the cap back on?
Thanks. Soak it overnight in solvent or something that will cut grease and scrub it. Mine was plugged and I was able to clean it without taking it apart.
#30044 08/05/2003 12:51 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | My vent cap/nipple was rusted solid. Couldn't open it up or find a new one anywhere. Made my own out of a 1/8 threaded by 1/4 barb brass fitting. Then crimped closed one end of a 1/4 brass insert bushing for plastic pipe. Left the other end open and made a slight crimp in the bushing body. Put this over the barb fitting. The brass bushing rises and falls over the barb fitting but the small crimp in the body prevents the bushing from rising over the barb end of the fitting. Works fine. | | |
#30045 08/05/2003 2:25 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Couldn't figure out what the heck you guys were talking about until I went "down under". Sure enough on top of my rear axle housing (drivers side) sits this little cap. It's loose yet doesn't want to come off by hand, so I assume it is in working order. What one learns from the bolt.... I can take a pic if people are interested.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#30046 08/05/2003 3:17 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | cmayna, Would sure appreciate a picture. Mine is missing and I would like to know what I'm looking for. Thanks | | |
#30047 08/06/2003 12:32 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Will take a couple shots when I get home. Stay tuned.....
#30048 08/06/2003 1:38 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Here it is. Almost looks like it was hand made but it spins freely and won't come off accidentally. Almost looks like something just pulled off the ocean floor next to that Florida bound Cuban AD. [img] http://www.cmaynard.com/Truck/rearaxlevent.jpg[/img]
#30049 08/06/2003 2:07 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Boy, that is an ugly thing.....thanks for the pix..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#30050 08/06/2003 2:22 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Cmayna,,,,, If that piece in the front of the pic is your brakeline, I suggest replacing it soon,,, Man, that thing is rusty
#30051 08/06/2003 3:59 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Replace me brakeline???? I just pulled the nipple off the USS Titanic and just knocked off the barnicles...Yes I agree that it needs to be replaced but question before or after my wife drives my truck to her work?
