3 members (Otto Skorzeny, 3B, 1 invisible), 45 guests, and 9 robots.
Topics128,013
Posts1,055,322
Members48,419
#29985 06/04/2003 1:49 PM
Ok I've taken the back plate off my 59 wich is a 69 Grand prix donor rear end housing. The gears look brand new. It is a 10 bolt not posi traction, so what is the normal gear ratio for these things? I've counted the teeth divided the drive shaft gear and my figure just doesn't make sense! popcorn The Truth is Out There (HELP!!!)
#29986 06/04/2003 2:11 PM
What are the numbers ?
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#29987 06/04/2003 4:56 PM
Poncho rears had an axle code stamped into axle tube (usually driver side). clean the gunk off and get the code, it'll tell what car, ring gear dia, & ratio was stock for that rear.
Assuming its a 10 bolt from a '69 GP, its likely a 8.5" and could have any common ratio (depending on carrier) between 3.08 to 3.70.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#29988 06/04/2003 5:05 PM
Ok!!! Thanks guys them maybe my figure of 3.55 is not to wild then. Appreciate the help!! popcorn
The Truth is Out There ( Yes it is)
