0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29983 07/24/2003 8:04 PM | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | The rod that is hooked to the E brake handle then goes thru firewall to bracket on frame. Is it supposed to be straight mine has a bow in it,thought it might be bent for clearance purposes ,I have not installed it yet and was just wondering Thanks Wayne
1956 GMC TF 1/2 ton 1955 GMC 500 model (Gumby)
#29984 07/24/2003 8:11 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | mine isn't, and if yours shouldn't be, then it won't hook up to the right spot - straighten'er out!!
Bill | | |
