1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29769 11/15/2004 4:19 PM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | I've got about 1500 miles on the 61 Apache since rebuild. It's been running fine and not burning any oil. It was very cold here this morning, about 25 degrees. The engine started fine and I drove the Apache to work. After about 25 miles when the engine was completely warmed up I noticed a puff of smoke---couldn't tell if it was white, blue or gray---coming out of the exhaust pipe when shifting from second into third. I have not noticed this before and am a little concerned. Could it be because of the colder weather? I've driven it all summer without noticing this, but this morning was the coldest weather I have driven it in. There was no visible smoke any other time, just when shifting from second to third. Any thoughts? Thanks.
Not quite as lean Not quite as mean, but Still a Marine!
#29770 11/15/2004 6:19 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Why don't you try pulling over to the side of the road and watching the exhaust closely after you notice the puff of smoke. This way you'll know if the smoking is constant or truly only when you shift from second to third.
Then again if you see smoke shifting second to third, I can't think of any reason why the same wouldn't happen going from first to second. The same thing is happening engine-wise - a sharp decrease in rpms. I'm sure Hotrod Lincoln can give a good diagnosis on this one.
-ftyler | | |
#29771 11/15/2004 8:32 PM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | I did pull over and check, and it's running clear. I drove it some more today and it only did it part of the time. Had a little bit of a backfire when starting out from first once, it's not done that before. I'm thinking maybe the carb might be set a bit too rich?
#29772 11/15/2004 8:58 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Maybe the carb is set a bit too lean. I believe a lean condition would cause the backfire - rich causes bogging and smoke (and a reduction in performance).
I'll wait for the experts (Hotrod, Tony, Fred T, etc.) to chime in for a better analysis.
-ftyler | | |
#29773 11/15/2004 9:53 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | It's cold....my guess is that it's blowin' a little steam(condensation) I bet it goes away when spring comes
I've enough water comming outta the 39 that floks tell me the head gasket blowed!!! Been 'Blowed' for ten years | | |
