1 members (Hotrod Lincoln),
55
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29763 11/24/2001 3:44 AM | Joined: Dec 2000 Posts: 9 Member | | Member Joined: Dec 2000 Posts: 9 | My street truck rod 65 chevy , has a 350-350turbo, it has after market power assisted brakes, but they just stopped working last night, the brake fluid is fine but no power brakes, help!,thanks kool guy  | | |
#29764 11/24/2001 4:43 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Do you have a vacuum leak?
Do you hear a leak when you step on the brakes?
I would guess the vacuum line to the manifold is either lose or has a hole in it,possibly the checkvalve at the connectionon the brakebooster.
The other posibility is there is a problem with the diaphragm in the brake booster.
#29765 11/25/2001 7:05 AM | Joined: Dec 2000 Posts: 9 Member | | Member Joined: Dec 2000 Posts: 9 | | | |
