1 members (baldeagle),
100
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29712 11/15/2001 10:44 PM | Joined: Aug 2001 Posts: 6 Member | | Member Joined: Aug 2001 Posts: 6 | I took the trip down to indy yesterday to help my sister rebuild her house. Every time I let off of the accelerator my engine (454) would backfire quite badly. Luckily the trip was at night and I could go almost the entire way without altering my speed. If I let off the accelerator very slowly I wouldn't backfire very much. But it is popping now even at idle (at least it was after the trip, maybe now that it isn't so hot it would be alright). I really don't know what causes backfires other than timing, I have new adjusted points, recently adjusted valves, new timing chain and recently adjusted timing. Known problems, exhaust leak at head (bad bolt hole), choke is stuck open, air filter housing pinches throttle body (I have ordered the spacer). Thanks a lot | | |
#29713 11/15/2001 11:35 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | the mixture could be too rich in your carb, or the float could be stuck open or you could have a vacumm leak. Mine used to do that, and it turned out that it was sucking air between the carb and the intake manifold.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#29714 11/16/2001 12:20 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You could have sticking valves. Check it with a vacuum guage.
#29715 11/16/2001 3:35 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | The cause of the backfire is the exhaust leak. What causes it is when you let off on the throttle there is a lean mixture of fuel going into the exhaust, this mixes with the raw air coming through the exhaust leak at the manifold, when there is enough of this, and it hits the hot exhaust pipe or muffler it will explode. If you fix the exhaust leak it will stop the backfire.
kdot em3
#29716 11/16/2001 4:22 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Racecarldad is right. Fix that leak and the problem should go away. One other thing might cause it. If you have a AIR (Smog) pump, the diverter valve might be bad or unhooked. It will cause similar problems. | | |
#29717 11/16/2001 5:09 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Check the EGR valve that it is closing fully,It should shut when you let off the gas if it does not you get a super rich mixture going down the tail pipe. Blew up a couple of mufflers before i found it. (Guys at the parts store could not figure how the seam could split the full length :rolleyes: ) | | |
#29718 11/17/2001 4:08 AM | Joined: Aug 2001 Posts: 6 Member | | Member Joined: Aug 2001 Posts: 6 | The leak is between the heads and the headers, not the manifold and the heads, but this wouldn't make a difference, would it? Still raw air and lean fuel mixing. Thanks again. | | |
#29719 11/18/2001 4:49 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | Any exhaust leak you can hear that is up close to the engine[before the exhaust pipe goes 2 or 3 ft.] will suck raw air in and cause the backfire. I have seen people use a product called [muffler mend] or something like that to stop the raw air from getting mixed with unburnt fuel. This [muffler mend] comes in a tube like calking. You put it on when the exhaust is cold and then start up the engine and let idle till the exhaust is hot then shut it off and let it set for about 30 minutes. This will let it set up like cement and it should stop the air leak. I just thought , I believe it is called muffler cement.
kdot em3
