8 members (walter74, moparguy, TUTS 59, Wickedbass, 50Chevy3100, FAST55, Wally / Montana, Mike Burns), 91 guests, and 4 robots.
Topics128,065
Posts1,055,870
Members48,428
#29651 05/07/2003 7:34 PM
I am replacing the water pump on my '56 235. My shop manual says to remove block attachment bolts and remove pump/pulley/fan as one unit. One of the bolts is behind the pulley and I can barely get a wrench on it. Would it be ok to try and remove the pulley and fan first so I can get to the bolts easier?
#29652 05/07/2003 7:40 PM
oldblue,
If you have enough room to remove the bolts holding the fan and pulley on then it doesn't make any difference. Maybe you can just loosen the fan/pulley bolts enough to let the pulley move so you have a little more room for the wrench.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#29653 05/07/2003 7:57 PM
Heck I never knew that there is an "oldblue" and an "Olblue".
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#29654 05/07/2003 11:50 PM
I had the same problem. I just made that the last bolt to loosen and as I got started I pulled the water pump out making a little more room as I went. It was tight but with some effort it worked.
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#29655 05/08/2003 4:22 AM
Brian,
And bluebird too!
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
#29656 05/09/2003 12:02 AM
I don't believe I can get that last bolt started and tight with the fan/pulley installed. I'm going to put the pump on first and then try to get the fan/pulley bolted to the hub.
'Nuther question. I have a standard heater and the water pump has a threaded pipe that is screwed into a hole by the outlet that the heater hose attaches to. Will a new water pump have that pipe or will I need to remove the one from the old pump to put on the new pump?
#29657 05/09/2003 1:06 AM
You should save the threaded nipple. I have seen new water pumps come with and without it..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#29658 05/09/2003 6:39 PM
I picked up my new water pump this morning. NAPA ordered it for me. It did not come with the heater hose fitting. The part store guy was nice enough to remove the old one for me. Had to take it in the back and use a vice. Man was that thing in tight. He also recommended a silicone gasket sealer to use with the new gasket. He said to put a small bead around the pump side of the gasket and then stick it on the pump. Then put a small bead on the block side of the gasket before installing. Does that sound about right?
#29659 05/09/2003 7:01 PM
Yep, that's right, just be careful not to use too much sillycone.
Paint & Body Shop moderator
#29660 05/10/2003 12:20 AM
I'll try not to. By the way, could I use this same silicone for replacing my valve cover gasket?
#29661 05/10/2003 12:32 AM
When I replaced my valve cover gasket, I used weatherstrip adhesive. I glued the gasket to the valve cover and let it dry. Then I bolted the cover to the head.
That way, if I need to remove the valve cover to adjust the valves, I don't need to replace the gasket each time..
Bill M
53 GMC Hydra-Matic
Home Page
#29662 05/11/2003 7:51 PM
Well, I got the new pump installed. No leaks so far. How can I tell if it's really working? I took the cap off and I can see the coolant moving, but the lower hose isn't getting as hot as I remembered. The upper hose and heater hose are both hot to the touch. My temperature gauge doesn't work right so I can't go by what it shows.
#29663 05/11/2003 9:34 PM
I haven't seen many water pumps that don't work. They can leak or not leak, but it is a fairly safe bet that if they are spinning, they are working..
Bill M
53 GMC Hydra-Matic
Home Page
#29664 05/12/2003 6:53 PM
The lower hose is supposed to be cool, it sucks cooler water into the block from the radiator.
#29665 05/12/2003 7:05 PM
That makes sense. I never really thought about the direction of the flow. So once the thermostat opens it flows top to bottom in the radiator? Or the whole circuit is... out of block through thermostat into top of rad out bottom of rad into pump and back into block.
