1 members (MikeE), 70 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#29516 02/28/2003 3:35 PM
The brake pedal on my '53 3100 returns to position real slowly. I suspect that the problem is that the pedal return spring has lost a little tension over the years. When I stretch the spring out a little longer the pedal pops back just fine.
I haven't been able to find a brake pedal return spring in any of the catalogs. Anyone know where I can get one?
Any other suggestions on what to look at for the cause of the problem or what to do to fix it?
#29517 02/28/2003 4:29 PM
Junior Member
Junior Member
You can probably find a matching spring at your local auto parts and/or hardware store. It is possible that your brake/clutch pedal assembly needs a good cleaning and greasing and/or the bushings in this assembly are "toast".
Good Luck
#29518 02/28/2003 5:18 PM
I found replacements in good condition at a local junkyard. Otherwise just take the old springs to a local hardware store and match up the size (diameter) and length.
Steve
55 1st Series 3/4 ton
#29519 02/28/2003 5:27 PM
Or the hole in the cab could be rubbing on it. This happens when the truck floor and/or cab mount have seen better days.
54 3100 with 235
62 flatbed dump C60 with 261
#29520 03/03/2003 7:57 AM
Z
Z Offline
Go to the HELP section at any parts store and get a pedal spring!
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
