1 members (Otto Skorzeny), 115 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
Junior Member
Junior Member
I just got my reman rochester B single barrel carb from the local NAPA store. Everything looks good except the choke. The one listed for my truck (230 cid)is a manual choke but the one on the new carb (215 cid Pontiac--my engine) is an auto choke. So my question(s) is:
1.If I order another carb for a truck application (230cid) would it be too big for my engine (215cid)?
2.If I wanted to remove this choke and install my manual choke, how hard is it/is it possible? Thanks for any help provided.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
Junior Member
Junior Member
Anyone???? :confused: :confused:
The carb should work on your 215. If anything, the trucks were under-carbed. Drive it for a while then check your plugs. if they're carboned up, rejet the carb. As far as swapping chokes, I don't think you can do it. I would run the auto choke. I'm assuming it's one with a heat tube, which runs down to the exhaust manifold.
When you ordered the carb, did you tell them you wanted a manual choke? If so, take it back.
Fred
52 3600
69 C-10
