5 members (Otto Skorzeny, Woodcmiami, 3B, 55shaker, Wally / Montana), 216 guests, and 1 robot.
Topics128,086
Posts1,056,098
Members48,434
#29504 11/08/2002 4:04 PM
My 216 packed it in and I am taking this opportunity to swap it for a 235 (46 GMC). A friend of a friend gave me an engine that appears to be very similar to the 216. The casting number, #2135412, comes up as a 248,270. Is this a 248? or a 270? My second question - The 216 flywheel was held on with 6 bolts and this other engine uses only 4 bolts - Is there an adapter available? or should I be looking for another engine?
46 GMC
#29505 11/08/2002 4:16 PM
The 228,248,270 GMC engines are better, but totally different than the Chevy engines of the same era. You should find a '55-'62 235, as it will be an almost drop in replacement.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#29506 11/11/2002 1:23 AM
I agree with Chiphead in that I have a 54 235 in my 46 Chevy, and it is easy to get parts & runs like a champ--
#29507 11/11/2002 1:42 AM
GMC and Chevs have diff #'s. You sure you had a 216 in that GMC?? GMC also has the engine size in first three numbers of serial stamped behind distributor on machined angle surface. Keep in mind 216 is shorter than the 235 late and GMC engines. May need to do radiator mods or undo mods done to yours to put in Chev engine in first place! Even the front motor mount is diff at x-member from GMC and Chevs. GMC is better engine too. :p
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#29508 11/11/2002 3:25 AM
This is where it gets interesting - After looking at lots of ID #'s, and not finding mine, I've sort-of determined that it is a 216.
The punched number on the plate just behind the distributor has the number C432317 and the cast numer, on the other side,is 3695451.
The transmission has the number "8 GM 590474" on the left side. Any help on this is also appreciated.
Thanks for the reply's
46 GMC
#29509 11/11/2002 11:03 AM
I believe canadian GMC 1/2 ton trucks had 216's
Paint & Body Shop moderator
