2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29332 06/03/2004 2:24 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | .....found a thermostat housing that fits a 235 and has a hole tapped and threaded for a temperature sensor? I'm wondering if one of the modern, electronic engine systems might have a thermostat housing that will fit on a 235. | | |
#29333 06/03/2004 3:00 AM | Joined: Jul 2003 Posts: 14 Member | | Member Joined: Jul 2003 Posts: 14 | Most of us liberals know where to get them but we won't tell you! | | |
#29334 06/03/2004 3:43 AM | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Paul, even if a ready-made housing can't be found, it's a pretty simple job to either drill and tap a hole in an original housing, or silver solder or braze a pipe fitting onto the top of one. I've done that at times when I needed another pipe thread for a fan switch or temp gage. Jerry
#29335 06/03/2004 4:00 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Hotrod, I've been thinking about that. I don't have the tools for the job, so I'd have to get someone else to do it. That's sure an option though. | | |
#29336 06/03/2004 4:47 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I believe a GMC has an additional hole, or an extra threaded hole, in it.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
