| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29326 12/23/2001 11:58 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I am getting ready to remove a 4 spd tranny from a 51 GMC to replace the clutch. In the shop manual, I notice a diagram with a picture of a gearshift removal tool. The manual says that the tool is to be placed over the lever, then press down and turn to the left to remove only the gearshift.
I thought I may have to pull the top cover in order to remove the gearshift and give me enough room to slide the tranny out from under the truck. Has anyone ever seen a tool like this or come up with another way to remove only the gearshift lever ? Thanks,,,
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#29327 12/24/2001 1:34 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I think I used channel locks to remove my handle, I don't remember now how I pushed the ring down to turn it. Seemed to me it wasn't to hard.  | | |
#29328 12/24/2001 1:44 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Just used a pair of pointy vise grips, Thanks for the tip..
#29329 12/24/2001 8:06 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | I never bother with the "tools". Put a rag over the top of the shift lever base, push down and turn. They usually pop right out. | | |
#29330 01/02/2002 7:49 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 |
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#29331 01/02/2002 9:34 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Obviously you guys have never had to remove on from a rusty junker settin' around for 20 years w/windows and doors open. :rolleyes: I can remove my "good" ones by hand or with pliers like you say, BUT, the old rusty, stuck ones take lots more. I have used two small boards, one on each side of handle and pushed down after lots of oil/penetrant but it's hard to get them to grab and not slip to make the turn. I have always wanted one of those tools, contacted old maker and they had none or no ideas. I was once thinking of getting some shop or maybe guys at work (GM) to make me one. Don't know exactly how the bottom part is set-up. Manual says to put the "tabs" into the shift slot. Don't know what "tabs" are there or ??? Machining a taper or concave should be easy and slot and handles, don't know about these "tabs"? I've also heard of guys making one out of a pipe that just fits the outer, flatter edge on cap and weld handles on it. Have to pass over the shifter arm to use. I seldom am able to remove the knobs, so would make the "slot" in pipe to pass over lever. This is probably what I am going to try first. :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
