0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#29304 08/28/2004 3:24 PM
Junior Member
Junior Member
Hello Group,
Has anyone ever tried to adapt the A/C- Heat assy. from another car to the firewall where the battery mounts and just move the battery?
If so what veh. did you rob the A/C from.
Thanks Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#29305 08/28/2004 9:46 PM
I didn't adapt one, I used a Vintage Air system that was (supposedely) engineered to fit. It clears the battery box nicely, lines exit sheet metal below battery, one screw goes thru firewall to hold evaporator case in position. (1959 1/2 ton)
If you want to try and adapt one, try to get one from a smaller import car, they are usually self contained under the dash and small enough to fit behind the dash. Not a whole lot of room there.
