2 members (TooMany2count, J Lucas), 33 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#29258 11/02/2001 10:49 AM
Help!! Need some knowledge. Im trying to put a 350 in my 61 apache (originaly a 235)was wondering if my flywheel from the 6 cyl. will fit my 350 (dont know how many splines the output shaft has on my tranny?)I'm also in desperate need of a front engine mount for a V8 anyone know were I could locate one?
#29259 11/02/2001 10:52 PM
V
V Offline
Don't think the old flywheel will fit, and you probably wouldn't want it if it did. Why? Because six cylinders have smaller diameter clutches that a small block will burn up in short order. When you get another flywheel, have it resurfaced and then get the biggest diameter clutch you can to go with it. When you go to the parts store, as for a clutch "kit" that will include a new clutch, pressure plate and throwout bearing. Typically you could ask for a kit from 60-72 chevy truck with a small block and the same transmission you have.
Rather than fighting with the front mount for a small block, you could get the mounts from a later small block truck 62-66 - they should bolt to your crossmember. There might be a few problems with this, because I'm not sure how things were on those torsion bar trucks. Check it out for yourself.
If you have a floor shift transmission (SM420), it should have an 18 spline input shaft, which is very common. You won't have any trouble matching it up to a clutch.
I beleive the column shift have the same spline count, but I'm not sure.
#29260 11/04/2001 9:25 PM
Vaughn: Thanks for the info!!
#29261 11/13/2001 4:03 PM
Junior Member
Junior Member
I used the the horseshoe front mount when I repowered my '61 back in '71, it was a great mount. I've now spent the last 3 months looking for one and have decided that they're not being produced any more. It would be easy to build if you have the tools, and as I've still got my '61 panel, I could measure it up, if your still interested.
