0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29075 05/08/2002 4:09 AM | Joined: Apr 2002 Posts: 42 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 42 | i need to buy a new carb cause the bolt flange is broken and it sucks air through so where is a good place to buy a carb and how much would they run. it is a 235 engine the guy before me put it in, thanks Hudson | | |
#29076 05/08/2002 4:53 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | WHich model carb do you have?
#29077 05/08/2002 9:03 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | The throttle body is usually cast on these and it comes off the main float body with two screws underneath. You should be able to find an old carb and just use the throttle body part. OR You may be able to weld broken ear back on and then have to make base flat again by setting on sandpaper on good solid flat surface and pushing down firm and moving back and forth w/out rocking to make it flat again. They used to "shave" heads on old bikes in past that way. Or have it machined if cost effective.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#29078 05/09/2002 4:10 AM | Joined: Apr 2002 Posts: 42 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 42 | i am not sure how to find out what carb it is could ya tell me how to find out? Thanks Hudson | | |
#29079 05/09/2002 5:15 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | There should be some numbers or sets of numbers on the carb.You should be able to get an auto-parts store to help you identify it. .Does it have any names on it? like Carter or Rochester?
