| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28986 12/20/2001 9:05 PM | Joined: Nov 2001 Posts: 18 Member | | Member Joined: Nov 2001 Posts: 18 | Hey what have you guys had luck with as far as engine degreasers? Ive used the pepboy brand "gunk" but that seems kinda weak. Do you guys have a special heavy-duty stuff you use? I want to clean off the engine so I can paint it, but I want it to be free of grease as much as possible. I was thinking of even trying muratic acid! Thanks for any info | | |
#28987 12/21/2001 12:23 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Don't use muriatic (hydrochloric) acid. It will only remove this kind of grease by chewing away some metal. I'm interested in the ways to clean old grease. Does anyone use Gunk and car washes or is that too environmentally bad. Are there steam cleaners any more? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#28988 12/21/2001 12:35 AM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Use Gunk. DO NOT use the "foaming" kind, it doesn't work. All other brands I have used don't work as well. Some say to use oven cleaner, it works for them. The non-foaming gunk works just as well and the price is about the same as oven cleaner. Keep it off your skin, because it will make you sick for a couple days. Use gloves, etc. | | |
#28989 12/21/2001 12:50 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Castrol Super Clean works fairly well, just make sure you wear latex or blue nitrile gloves. It will dry out your hands big time  . Also, keep it away from your painted surfaces, like that new paint job on your truck. It will damage the finish. If you have an aluminum manifold with a bright finish, it will tarnish it. It must have some kind of acid in it, but I am not sure. Some old timer told me to use kerosene or diesel, but I have never tried it. I have noticed a "kerosene" odor when using the rattle can "Gunk engine brite".........
*** GMC ***
#28990 12/21/2001 1:20 AM | Joined: Apr 2000 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 71 | We use a liquid called Purple Stuff around here. It is packaged under several other names, but is always purple colored. That Mean Green cleaner seems to be about the same but has the smell added to it. The purple stuff won't hurt paint unless left to dry on it. However, don't get it near any silver powder coated wheels or it will turn them dark grey. | | |
#28991 12/21/2001 2:18 AM | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | Same question came up a while back and someone suggested using wife's Fantastic. I tried it - darn works like a charm. | | |
#28992 12/21/2001 3:04 AM | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | oven cleaner also works for heavy crud removing. It contains lye, so be careful and use gloves and goggles. | | |
#28993 12/21/2001 7:04 AM | Joined: Feb 2000 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 95 |
Houston? , We have a problem!
#28994 12/21/2001 8:48 AM | Joined: Feb 2000 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 95 | gearhead56/WALLY: check out your nearest truckstop and find out if they have a truckwash. The better truckwashes will have steam cleaners and "REAL" industrial grade (2500psi) pressure washers. They should blow the grease, paint and chrome off of most surfaces without any problem. They also have a sump to take care of any enviro/concerns. You could also try paint stripper, that will eat grease, (and anything else) in a heartbeat!! Be CAREFUL!!!
#28995 12/21/2001 4:07 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | I have been using a mix of diesel varisol and gunk to remove the heavy grease from parts and frames, but it does leave an oily film that has to be removed if you are going to paint, ie engine blocks but then in most cases you have to wirebrush the casting to remove the rust film any wayand wipe down with acohol or laquire thinner before painting, on painted parts i just leave the oil film for storage, to stop the surface rust from forming. | | |
#28996 12/21/2001 5:07 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | After you get the big chunks off get yourself a gallon of Simple Green. Use it straight out of the bottle, it works great. Make sure there is no oil residue on your engine before you paint it or your paint will just fall off. Good luck. | | |
#28997 12/22/2001 12:52 AM | Joined: Nov 2000 Posts: 45 Member | | Member Joined: Nov 2000 Posts: 45 | I have found that, especially on "old" heavy grime, spraying it down with WD40 first, then a little elbow grease, then hosing it down with Gunk, then some more elbow grease works the best for me. Be aware of your surroundings when you do this or you may have your neighbors, EPA, etc... on your butt as that Gunk can really stink for days. I try to use the local do it yourself carwash place when possible. Then I don't have to worry about cleanup. I never paint right afterwards, I always use some laquer thinner or denatured alcohol, etc... and give it a good scrub down. Prep it like you would anything else before painting and you shouldn't have any problems. | | |
#28998 12/22/2001 2:16 PM | Joined: Nov 2001 Posts: 18 Member | | Member Joined: Nov 2001 Posts: 18 | Thanks guys. I use the simple green on all sorts of things, I know that stuff is good. But on my 1956 grease I need to try some heavier stuff, maybe the oven cleaner or that fantanstic. Good ideas! | | |
#28999 12/30/2001 8:44 PM | Joined: Nov 2001 Posts: 18 Member | | Member Joined: Nov 2001 Posts: 18 | Just a note, a pressure washer works pretty good, im going to follow it up with a sand blaster | | |
