0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28935 10/06/2003 5:32 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | I've heard referances to a 2 Barrel carb that some of you are using on your in line sixes. I have a couple questions. Is that a front/back carb (second barrel on demand like a 4 bbl 3/4th barrel)or is it a side by side, both bbls always operating? Can it fit the standard intake from a 68 250? If so where can I find it or what company makes it? Heck, I'll even take a bad one and rebuild it!
35 + years of rollin' steel!
#28936 10/06/2003 7:23 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It's a Holley-Weber progressive two bbl. You can buy them from Langdon\'s Stovebolt . He also sells an adapter to go on a one bbl. manifold, but it's a bit on the ugly side. Progressive means that it closes off the secondary until it's needed, helping torque and mileage. Call him up and talk, he has a lot of good info on them.
Fred 52 3600 69 C-10
#28937 10/07/2003 11:46 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Fred, Thanks for the info. I'll be contacting the site. Have you used this carb? Does it help with the gas mileage as well as power? Any down side to it?
