2 members (mo2cyl, panic),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28815 10/17/2004 11:30 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I ran a compression check on the new purchase, has 80-85 psi all cylinders. I know to look for uniformity, but this number seems low to the old hot rod V8 head of mine. Is this typical of a Stovebolt? Not sure if its old age creepin or gas at $2 a gallon but this is now my second six in a row I'm planning on keeping! Brian | | |
#28816 10/18/2004 12:15 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I had a fiddle with my truck , just to help compare ,, mine is close to 120 average . | | |
#28817 10/18/2004 12:57 AM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | My Motor Magazine auto repair manual lists Chevrolet compression ratios from 1940 to 1953 from 6.5:1 up to 7.5:1, and compression pressures from 110 to 112. Now, that can't be correct, but I wouldn't get too concerned about consistent pressures of 85 pounds. The next gauge you try might average 100 pounds or more. Uniformity is much more important than the gauge numbers. Jerry
#28818 10/20/2004 4:29 AM | Joined: Jun 2003 Posts: 41 Junior Member | | Junior Member Joined: Jun 2003 Posts: 41 | Might be the gauge, try another one, my 235 shows 125 to 130 across the board and this is a far cry from a new engine. I'm getting some blowby and get about 300 miles to a quart of 20W50. | | |
#28819 10/20/2004 5:42 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Too late, I've almost got it out. It has been sitting & has a bad freeze plug(I hope, water pours from the flywheel) & clutch is gone. It purrs like a kitten so I am gambling & its gonna be OK w/some work. There is a front freeze plug leaking from rusting out so I hope the same for the rear & not a crack 3" long. I thought maybe poor valve sealing from not running could account for low #s. Brian | | |
