Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Wayne67vert, crenwelge, 1 invisible), 475 guests, and 6 robots.
Topics128,282
Posts1,058,494
Members48,490
#28815 10/17/2004 11:30 PM
I ran a compression check on the new purchase, has 80-85 psi all cylinders. I know to look for uniformity, but this number seems low to the old hot rod V8 head of mine. Is this typical of a Stovebolt? Not sure if its old age creepin or gas at $2 a gallon but this is now my second six in a row I'm planning on keeping! Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#28816 10/18/2004 12:15 AM
I had a fiddle with my truck , just to help compare ,, mine is close to 120 average .
#28817 10/18/2004 12:57 AM
My Motor Magazine auto repair manual lists Chevrolet compression ratios from 1940 to 1953 from 6.5:1 up to 7.5:1, and compression pressures from 110 to 112. Now, that can't be correct, but I wouldn't get too concerned about consistent pressures of 85 pounds. The next gauge you try might average 100 pounds or more. Uniformity is much more important than the gauge numbers.
#28818 10/20/2004 4:29 AM
Junior Member
Junior Member
Might be the gauge, try another one, my 235 shows 125 to 130 across the board and this is a far cry from a new engine. I'm getting some blowby and get about 300 miles to a quart of 20W50.
#28819 10/20/2004 5:42 AM
Too late, I've almost got it out. It has been sitting & has a bad freeze plug(I hope, water pours from the flywheel) & clutch is gone. It purrs like a kitten so I am gambling & its gonna be OK w/some work. There is a front freeze plug leaking from rusting out so I hope the same for the rear & not a crack 3" long. I thought maybe poor valve sealing from not running could account for low #s. Brian
