0 members (),
40
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28596 07/13/2004 1:44 PM | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | i didn't think the granny low(bull low 1st gear)4speeds were that common in55,56,57 chev trucks. but 3 out of 4 trucks i have seen lately at shows had them instead of 3 on the tree.so my question is was the 4 speed real common ? my truck is 4speed as well. just curious. :rolleyes: george | | |
#28597 07/13/2004 2:49 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | They're not rare, by any means. I think all the 3/4 tons of that vintage had the granny box, most of the 1/2 tons had the 3 speed. Designation for the tranny is SM420.
Fred 52 3600 69 C-10
#28598 07/13/2004 4:19 PM | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | OK, next question- - - -what's one worth? I saw one of these at a local wrecking yard, supposedly in good condition with a V-8 bellhousing attached (the one with the crossmember motor mounts) and the asking price was $100.00. I don't need it, since I've got the same setup in my 59 Suburban, and about 5 of the hydraulic-clutch V8 bellhousings, but the price seemed to be good. Jerry
#28599 07/13/2004 7:13 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Jerry, I've seen them sell anywhere from $50-200. The 4x4 guys love them with the 7.00 granny gear. They fit into a jeep without a lot of work. The SM465 with its 6.55 first is desirable and more bulletproof, but considerably bigger and heavier. If I needed one, I would pay $100, but not just to have it sitting around. Of course, in some areas they are as scarce as hen's teeth, but not here.
#28600 07/13/2004 8:59 PM | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I've got a couple of them already, one original-equipment box in a 59 model 3800 1-ton, and one of uncertain year that I swapped into the Burb about 20 years ago. I think it's a late-60's trans. Do you think either of these would handle the torque of a 120-HP turbo diesel inline 6? I'm considering building up a 3/4 ton running gear with that engine, a takeout from a UPS box van. Not sure which cab I'll use, as I've got a couple to pick from. It's probably going to get a home-built wrecker bed installed on it. Jerry
#28601 07/13/2004 11:08 PM | Joined: Nov 2003 Posts: 53 Member | | Member Joined: Nov 2003 Posts: 53 | My 1963 Chevy Shop Manual lists the input torque capacity of the SM420 as 281 ft-lb. It was used, however, in 50 and 60 series trucks with all available engines including the 348 and 409 V-8. | | |
#28602 07/14/2004 12:23 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | What's so scarce about hens teeth anyway ?
I have an extra one in my garage which came very handy when I decided to install a backup light switch in my tranny. Used the top plate of the spare tranny as my guinny pig and it worked perfectly. Swapped top plates and everyone is back in their places, fat and happy.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#28603 07/14/2004 9:12 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | I have 3 of them and have turned down a couple more free ones, one of which had the PTO attachment. They are pretty common around here. I wished I had taken the PTO tranny, because the 51 3/4 ton wrecker chassis I bought has a Galion winch, but somebody borrowed the PTO from it. Ralph | | |
#28604 07/14/2004 10:56 PM | | Anonymous Unregistered | | Anonymous Unregistered | Hello Hotrod, I thought that all UPS trucks went to the great parking lot in the sky. how did you come across an engine from UPS? At one time there was a thread about the 18 or 19in wheels that were on the smaller box vans with 8 lug holes that supposely fit on the front ends of the 3/4 and one ton ads without fouling the tie rod ends. Do you know anything about this? tony'n weatherford  | | |
#28605 07/15/2004 1:57 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Hotrod Lincoln: ... It's probably going to get a home-built wrecker bed installed on it. I'm curious about the wrecker bed. Have you already built it, or are you just planning to build one? Have you made plans? This is something I've thought about doing...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#28606 07/15/2004 8:04 AM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | Scarce? Oh yeah. Here in Hawaii there are way more 4x4 builders than old stovebolters so open driveline SM420s are nearly impossible to come by. Shipping one in from the mainland costs an arm and a leg, too. | | |
#28607 07/15/2004 12:29 PM | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | these tranny are in a lot more old trucks then i originally thought! abuddy of mine even has one swapped in a jeep.  | | |
#28608 07/15/2004 4:50 PM | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I made a one-time racehorse deal on 8 retired UPS engines, with a buddy who was a shop foreman for UPS. I got 7 running engines, and one without a cylinder head. (I paid just about scrap iron price for running engines!) They're 120 HP turbo diesels, about the size of a 292 Chevy, but somewhat heavier. I dynoed one, and it makes its rated horsepower, 120 @ 3600 RPM. I've got 5 running engines left, and the parts engine. They were made by Onan as power generator engines, and when Cummins bought Onan, they sold them to UPS as delivery van engines. The UPS demand exceeded Cummins' ability to supply spares, so they retro-fitted to a different engine. These engines were used interchangeably with 292's and F*rd 300's, so a van could be converted from gas to Diesel with just a fuel change. They're set up for Chevy V8/292 bellhousings, with the old hydraulic-clutch bellhousing with the throwout fork on the passenger's side. They're equipped with a 12" Chevy clutch, and any Chevy-pattern trans will bolt up. I've got a New Process 235 4-speed to use on this project, but I'm searching for a 5-speed Clark with 5th. gear overdrive, with a Chevy bellhousing bolt pattern. No luck on the wheels, as my contact man retired a couple of years ago!
I've got a line on a couple of wrecker beds, with PTO-driven winches, or I might fabricate my own bed and booms, and use a PTO winch. I ran a wrecker service for a while, and did most of my own maintenence, and even built a few special-purpose beds and rigging. This project is way down the "to-do" list, so I'm not locked into a final design yet. Jerry
