4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#27935 03/21/2003 2:51 PM
My 1966 Chevy has a Rochester "B" carburetor on the 250. It is the original carburetor that I rebuilt several years ago. It has always had a problem leaking where the top meets the middle section. Now after you drive it when you restart it is often flooded and takes a while to run correctly.
I have tried to adjust the float level a couple of time, but to no avail. I am looking into having it professionally rebuilt or possibly replacing it with the Holley-Webber that Tom Langdon sells. Any thoughts or suggestions out there?
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
#27936 03/21/2003 6:39 PM
Mike,
I have a 66 with the same carb doing the same thing. I am going to replace mine with a Carter YF carb based on a recommendation from Ken Brown. A rebuilt unit from my local store is $120.00.
Good Luck.
BigMac
#27937 03/21/2003 9:47 PM
V
V Offline
What you have there is a ' Monojet ' carby , very good _but_ the air horn ofttimes warps resulting in un-repairable leaks , you can try (in emergency) _gluing_ the top on the body by painting the gasket with Permatex , I've done it but it's near impossible to open up for cleaning next year . consider replacing the carby complete
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
