7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible), 123 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
#27820 05/16/2004 1:56 AM
I finally got my 1953 GMC running for a couple of minutes then the radiator boiled over when it was still running. I have a new radiator, radiator cap, themostat and water pump but everything has been sitting for several months.
Does anyone have any ideas? Could it be a thermostat? I'm at a lost :confused:
#27821 05/16/2004 2:57 AM
If it was me, I would pull the thermostat and drop it in a pan of boiling water to see if it is opening. I have had new one's not open because they were binding. I would also probably try running it without the thermostat just to see if it quits over heating....if it does then you know it was probably the thermostat and just replace it with a new one.
Joe
#27822 05/16/2004 3:25 AM
Read my recent thread about "overheating agin", a couple ppl suggested to drill a small hole in the new tstat to allow the air bubbles to escape and it worked for me. (I was having the same problem as you)
#27823 05/16/2004 4:41 AM
Y
Junior Member
Junior Member
Y Offline
Quote
Chuck
#27824 05/16/2004 2:21 PM
Funny,
The thermostats I've bought for my truck has always had a small hole pre-drilled.
Craig
#27825 05/16/2004 2:28 PM
Thermostats from NAPA are 100% air tight! That is why I drill the 3/16" inch hole in the flange over the outlet hole. grin
#27826 05/16/2004 5:01 PM
Thanks for the great information. I'm working today so I'll give it a shot next weekend. grin
