0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#27723 08/04/2003 2:59 PM
Now that I've been using my truck almost on a daily basis I have noticed that every once in awhile (maybe every 10 times), when turning off the engine it backfires (not sure if this is the correct description) or burps during its last couple seconds of life, so much that the hood flaps up at the top and the wiper blades shoot up to 12:00 o'clock position. Kinda reminds me when having eaten too much ice cream the nite before, developing too much compression.
What's the cause ?
Sincerely
Ivanna burp alot
Craig
rollin on the floor w/ that description! grin good one! opens the old guys eyes, eh?
check yer compression, sounds like maybe a burnt valve? only does it when that cylinder winds down at the right time, and then it fires, but fired by heat rather than spark w/ the force having to go out the carb cuz the piston has too much resistance [crank about stopped] - or maybe timing? or you could quit feeding the poor truck cucumbers grin
cmayna: Sounds like timing to me!! Also what kind of gas you feeding that thing radishes wink popcorn The truth is Out There (Truck eats veggies?)
A can of beano with every fillup should fix it...
54 3100 with 235
62 flatbed dump C60 with 261
Try lowering the idle speed.
Mine was doing that ... my gas mix was to rich. I leaned the carb down and it hasn't happened since.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
sixpack, Funny you mention idle speed for my truck has been idling too high for the past 3-4 months (around 1,000 rpm) unless I quickly tromp on the pedal which then it drops to around 800. Thinking I might need to rebuild the carb.
Craig
Most throttle release problems with these seem to be linkage related. I put two springs on mine and it still does it sometimes.
54 3100 with 235
