3 members (Wayne67vert, porsche, delky), 104 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#27715 06/17/2002 3:53 PM
Is the exhaust manifold for a 270 similar or better yet, the same as the exhaust manifold for the 235, 216, 302, etc?
I just need to know how far I can expand my search for a replacement. I want to stay stock so Fenton Headers are not an option.
Also, does anyone know where I can find one?
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#27716 06/17/2002 4:30 PM
I just read this post in the lounge. Maybe you two GMC guys can get together..
garyradford
Stovebolter # 140
posted 06-17-2002 09:27 AM
hey good deal!
i have a good exhaust manifold for that truck real cheap- glad to see another stovebolter getting on the road!!!! e-mail me...
Posts: 33 | From: cicero ny | Registered: Jan 2000
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#27717 06/17/2002 7:26 PM
Interesting question, Since Patrick's "GMC Fentons" are really Chev 235 with the holes for the mounting studs elongated. A 270 exhaust manifold will probably fit a 235 with some work, but not sure if the ports would be an exact match, or whether the alignment rings will still be usable...probably not. Also doubtful if the Chev header pipe would mate up to the 270 exhaust flange.
#27718 06/17/2002 7:34 PM
In reading the replies and my original message I realized that I did not specify what I am looking for very well.
I have a 270 with an exhaust manifold that was cracked and at some time in the past was welded and ground down. I want to replace this manifold but finding 270 parts is not as easy as some may think.
I am getting my engine back from the shop with a complete rebuild and I now need replacement parts for the bolt on parts and pieces that are in bad shape. To make a long story short, I need a new exhaust manifold that will fit the 270 in my 55 1st, 3/4 ton GMC.
Any help that you may be able to lend would be much appreciated.
Tom
#27719 06/17/2002 9:49 PM
OK, that's a bit different. Any GMC exhaust manifold should mate up OK to your 270 head...but it may not dump in the same place. There are some good resources for used GMC parts at Inliners try Larrowe & Sons or Langdon's Stovebolt. Even if you don't want duals, Kansas Kustoms may be able to repair your old manifold. And certainly don't forget OldCarKook
#27720 06/17/2002 11:20 PM
Chevy and GMC manifolds will NOT interchange! Anything GMC will fit your head, however, the ports may not line up depending on what head you have and what manifold.
#27721 06/18/2002 12:34 AM
Jimmy, I am up in Fort Collins for a week or so and thought that while I was here I would look around for some good bone yards and maybe stumble on something that I could use. Do you know of any around the FC or Loveland areas?
Tom
#27722 06/18/2002 12:52 AM
Bluebird,,, check your e-mail.
