| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27541 03/15/2004 6:05 PM | Joined: Mar 2004 Posts: 77 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 77 | Hi, new guy here. Has anyone ever seen a large Rochester model B carb with an auto choke? This carb seems to be a 292 only item with 1 1/2" venturi and 1 3/4" throttle. (numbers approx-but this carb is obvious when held next to one off a 230) I'm trying to assemble a large B carb with an auto choke setup. Sounds like these truck carbs might have all been manual choke only. My stumbling block is that the large bore throttle body I have lacks the mount for the auto choke high idle cam. Thanks. Pete | | |
