1 members (Oswald), 59 guests, and 1 robot.
Topics128,051
Posts1,055,766
I've got a engine, in a parts COE I have that I'm not sure what it is. The previous owner said it was a 261, but I'm leaning more towards a 235. I purchased two COE's from this guy, a '54 Chevrolet COE, & a 55 1st series Chevrolet COE. Both trucks were supposed to have 261's, but they weren't identical. The engine in the '54 had the sergent strips, that were described in another thread, but the other engine does not. The engine in question, has a tag rivited to the block that says, "Rogers Remanufactured Engine", Cyl. 040, Main, 010, Rod 010 . It has a Casting No. 3733950, on the Block, & Casting No. 3835913, on the Head. What have I got ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Hemming\'s indentification page says the motor # is 54-55 Chevrolet Truck and the head is 235.
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
Thanks 'rick, Looks like it is a 235.
Spanky Hardy
1950 GMC 250 1-Ton
go to inliners.org the block is listed as a 54/55 261 block
spanky- block casting 3733950 checks to be 54/55 date. Block should contain crank forging 3701486 or 3701488. Rod forgings should be 3702448 or 3836456. That's to say if the rebuilder used the stock internals anyway. My info tells me head 3835913 is 235, 55, I think, but don't know for sure. I have seen other early 261 54/55 blocks without the captains bars. Just depends on the casting. I can tell you that Chevy made 3 different 261 engines from early 54 thru late 55. The early 54 engines with small diameter cam bearings and shim pak mains. The late 54-early 55 engines with large diameter cam bearings and shim pak mains. And the late 55 engine minus the shim mains. Your engine should have the high water pump and 6 volt starter, based on the casting. The original COE engines differ from the conventional cab model engines, as the exhaust manifold is unique in that it exits to the rear. Your engine should also have the offset air cleaner and may be Carter YF equipped. Check the suffix code on the engine. 54 261 engines start with N, or Q. Early 55 261 engines start with F, N, or Q. And to make it more confusing late 55 start with F, TD, or TA. There was a certain amount of overlap with the changes in the 235/261 engines and the changes in trucks from Advanced Design to Task Force, all taking place in less than a 1 1/2 year span. From what I have read the Flint plant could not keep pace with the engine assemble line so some 235 and 261 truck engines were made at Tonowanda were shipped out directly to the truck assembly plants. The NY plant usually did not make the 261 truck engines, but made car engines and light truck engines. COE trucks are way cool
Houston? , We have a problem!
Thanks guys, I guess I have a 261ci. engine , with a 235 head. This engine had supposedly been rebuilt, a second time, about 7 years ago, & not run. The COE, that it is in, had been butchered by someone trying to make a 5 window cab out of it. When I purchased it, along with the 261 equipted '54 COE, the P/O informed me that it had this, rebuilt, ready to go, 261 engine in it. After I got it home, & decided that the sheetmetal on this truck was useless, I removed the cab, & examined the engine more closely. I found that it was stuck, & was full of water.(cab had no top )I also noticed that it didn't have the captain bars, that the '54 COE engine had on it. I pulled the oil drain plug, & removed the water, & oil, & haven't touched it since. Was planning on selling it, if it was a 235, but if it is indeed a 261, I want to rebuild it again, & install it in my '51 1/2 ton pickup. Once again, I thank you guys, for your help. Any drawbacks to having a 235 head on a 261 engine.
Spanky Hardy
1950 GMC 250 1-Ton
