7 members (2-Ton, Shaffer's1950, Otto Skorzeny, Gdads51, stoveboltgator, klhansen, Rusty Rod),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,539 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27175 07/15/2003 3:51 AM | Joined: Jul 2003 Posts: 2 Junior Member | | Junior Member Joined: Jul 2003 Posts: 2 | Hey guys, I need help identifying the engine in a 1969 C20 I just bought for parts. Above the starter are the letters CON3 B39. The pad by the distributor is stamped F240J. There are no other numbers I can find on the block (until I clean it more). The head is casting #3836848. The port for vacuum wipers is still in the intake. | | |
#27176 07/15/2003 5:38 AM | Joined: May 2003 Posts: 7 Member | | Member Joined: May 2003 Posts: 7 | the code for your block reads 235ci manufactured febuary 3 1959
51T | | |
#27177 07/15/2003 5:41 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Amazing. The head number is from a 235, 1954-1962. Someone went to some work to get a 235 in a 69 truck.
Fred 52 3600 69 C-10
#27178 07/16/2003 1:03 AM | Joined: Jul 2003 Posts: 2 Junior Member | | Junior Member Joined: Jul 2003 Posts: 2 | Thanks for the information. I bought this at an auction after a local "mechanic" told me it was a 292. It was to replace the flathead in my '39 Pontiac, now I'll have to rethink the swap. | | |
