3 members (tclederman, Donf, 1 invisible),
71
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27090 12/12/2003 10:07 PM | Joined: Jul 2003 Posts: 6 Member | | Member Joined: Jul 2003 Posts: 6 | I am almost done rebuilding a chevy 235 I bought from a guy and I am about to put the flywheel and clutch assembly on. Most of the pressure plates that I have seen for sale are all 11" or 10" with flat splines where the throughout bearing goes, but the one that came with the engine is about 11 1/4" with splines that angle outward. The 11 1/4" is in a lot better shape and so is the flywhel that matches it. I've been told that if I used the 11 1/4" pressure plate I wouldn't beable to adjust the clutch enough to make every thing work because the splines are angled, but I was hoping that one of you guys could tell me which plate to use. Thank you for your help.
Brandon | | |
#27091 12/13/2003 12:43 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think I have the same clutch as you on my 261. The bolt holes for the pressure plate impinge on the ring gear land slightly.
I had to really work to get it all shoved in the bellhousing ( had to sneak the fork in last) and I had to use the skinny type throwout bearing but it adjusted just fine. It all depends on which throwout bearing you use.
#27092 12/13/2003 3:07 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I have the same setup as Josiah. It is a bear to get together. I was since told to go to a GM parts wholesaler and get a shorter ballstud to make assembly easier.
Fred 52 3600 69 C-10
