1 members (JW51),
96
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26751 05/06/2004 3:00 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | > I'm working on a 49 3600, my new project. 216. I have rebuilt the carb > (Rochester) and got it to run. If anybody has a CarterW-1 that they'd want > to turn loose of I'd love to get it to replace the rochester.Anyway. I have > replaced points, plugs, condendor, cap, rotor, wires and it runs ok, but > seems a little down on power. I'm getting a timing light and dwell meter > today. I know you can ck dwell with the plugs out, can you ck timing the > same way?? I'm hoping the timing and dwell with a valve adjustment will help > it run better. It ran for 45 minutes and went for a mile ride, then I did > the valve adjustment. Exhaust were all tight and intake were loose. When I > pulled the plugs(new) they were very black and soot covered. Any thoughts? > I'm going to set dwell and timing, run it again for 45 minutes and then > re-check valve adjustment. Also, the idle adjustment screw on the linkage > work it self loose very quickly. How can I help it stay in position? I know > I need to get a vaccume gauge to set the idle accurately, I'm planning that > for this weekend. I've also rebuilt the M/C and got the brakes to work > fairly good.
Went home last night with my new dwell meter. Already had plugs pulled, spun over motor, dwell was @ 40. Readjusted points a couple of times got dwell to 33-34. Also cleaned flywheel, found BB, marked it with white paint as well as tip of pointer, checked head bolt torque all ok but one a little loose, checked rocker shaft nuts torque. ok, carefully lubed each valve stem with tranny fluid and squired a little on the rocker shaft itself. Reinstalled plugs and cap carefully checking firing order. Tried to start, wouldn't. Checked carb, bone dry. grrrr.. added gas to tank, fired right up, ran for a couple of minutes. I decided to ck dwell one more time while engine was running, 40. Pulled plugs, reset points dwell w/o plugs in to 33. Reinstalled plugs, carefully rechecked firing order, fired up. After it ran for a minute or so it started backfiring VERY loudly and quit. Rechecked firing order, ok. noticed a little gas on the front of the carb. seemed to be coming from the fitting on the fuel line. Went ahead and pulled off top of carb to recheck float drop. Was @ 1 7/8 reset to 1/34, put Teflon tape on fitting. Got dark. I don't understand why it is backfiring. I'm positive the cap and wires are right. 153624. I do notice that if you are looking at the dist cap at the wire clip that holds the cap to the dist, #2 is just above the clip on the r side of the dist, #4 is just below the clip and them # 1 is below #4 pointing at the ground. This is how it was when I got the truck. It ran for 45 minutes the other day and NEVER backfired. Never got to ck the timing. Where do I go from her?? | | |
#26752 05/06/2004 7:31 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Did you get the cap cinched down correctly? If it is loose it will have problems.
The firing order is clockwise, it will run the other way but poorly, so check that. I have gotten it wrong.
Finally, check your distributor cam for wear. If the cam is worn out you will be able to adjust the dwell OK but the gap will end up way too narrow and the thing will misfire.
#26753 05/06/2004 8:10 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | After thinking over every thing I've done I realized that I had NOT run the truck after I did the initial valve adjustment which was done after "normalizing". The backfiring didn't appear until After I adjusted the valves. I'm thinking that if it ran before albeit down on power but with out backfiring why won't it run now. I did a quick cold ck on an exhaust valve That I had adjusted hot to .013 and I could not get the feeler guage inserted. I may have a distributor problem, but I'm thinking about doing a cold valve adjustment in the neightborhood of .009 intake and .018 ex ( I had set them .006 in .013 ex). The rockers all move smoothly and I did soak all the valve stems with tranny fluid after I did the adjustment. I do have another distributor out of a 235 that ran fine before I pulled the motor out of my old 50, but I want to settle the valve question first. I'm basing my guess on cold adj on just a guess, so Please express yourselves. Dave | | |
#26754 05/06/2004 9:44 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, if your valves are too tight you will definately have problems.
