3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#26725 12/05/2001 3:04 AM
I need some help with these tires I want to put on the rear of my truck. right now I have M-55 235/75R15 LT on all four wheels. I have these two tires, they are practically brand new, and they are M-606 31X11.50 R15 LT's. They are wider than the origionals by at least two inches. My concern is the clearance the backside of the tire and the back of the wheel well. I am afraid that they would rub and cause all kinds of head-aches. Has anyone put tires like these on thier truck? if yes were any modifications made? frown
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#26726 12/05/2001 5:17 AM
they'll be slightly taller as well as wider. Best way: Mount them up while you wait, see if they fit. If so, balance them and enjoy! If not, unmount them and yer only out a couple bucks and an hour of time. I'd bet they'd fit fine grin
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#26727 12/05/2001 6:49 AM
Anonymous
Unregistered
Anonymous
Unregistered
Hey Johnnny, I am pulling leftover pieces together from putting a factory 50 suburban together and will be rodding with the scraps. I have been thinking 292 + 200R4 . . . do you have any pictures of your rig? How did the tranny do clearing the lower firewall/floor? We want to see pictures! smile
#26728 12/05/2001 4:50 PM
I have BFGoodrich 31x10.5 ATs on my '65 C20 Fleetside and I have plenty of clearance on it. The truck sure looks mean with those on it too. I can't imagine that your truck would be much different than mine.
Aaron
#26729 12/08/2001 8:17 AM
lets say hypothetically that these tires dont fit. Would tubbing out the wheel wells be cost effective? Or should I stick with the same size tires I have now? I would lose about two inches of bed space between the wells, and im trying to keep the truck mostly origional, but small modifications I dont mind. Any thoughts? smile
Jonathan S. Keffer
#26730 12/10/2001 4:08 AM
gmc the other problem you may have is lower shock mounts i had to move mine inside the fram rail .i just swaped sides with lower plates and boxed the fram in about 6 inches and bolted stock shock mounts to them it will give you about 2 inches clearance
47 Chevy COE..52 TO 30
#26731 12/10/2001 5:26 AM
Hey, Ken. Haven't got that far yet with tranny..... if it dont fit, it will when Im done! I'll probably make my own mounts to get correct pinion angle and clearances.
Pics are a great idea, let me work on that and post them in here for all to see wink
John Kennedy
new site up!
#26732 12/10/2001 5:15 PM
There's not much difference in the tires. LT235/75R15 outside diameter is 28.8 with section width of 9.1. The 31x11.5R15 shows an outside diameter of 30.5 with section width of 10.8. That's about 5/8 of an inch on each side. I would go out and measure the clearance now to have an idea of what will be needed.
Fred
52 3600
69 C-10
