| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | Hi there! I just bought a 1962 chevy flatbed. I think it has a 292 straight 6? Anyhow when I drive off and switch gears the truck sputters and backfirea a little bit until the revs pick up. Any suggestions!!!!!!!! thanx :confused:
1950 1/2 ton 3 window
| | | | | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | Try raising the float level in the carburetor, check for a bad accelerator pump, and/or late ignition timing. It's either lean, late, or both. Jerry
