4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#26477 05/06/2004 5:35 PM
If you are shopping for tapered roller bearings for your AD truck, here are #'s to look for:
Inner seal: National #6064
Inner bearing and race: MBS #909052R
Outer race: Timken #LM11919
Outer bearing: Timken #LM11949
I just bought a set from D&D off ebay for $99 & shipping. It does pay to shop. And it is a lot easier if you know the numbers.
Hope this helps. grin
#26478 05/06/2004 7:31 PM
Is that 1/2 t or 3/4 t? I'd love to know the 3/4t bearings, but I already have new ball bearing . Oh well
#26479 05/06/2004 8:57 PM
That's 1/2 ton. Doesn't 3/4 ton already have tapered roller bearings?
#26480 05/07/2004 1:02 AM
3/4 ton has Ball bearings (front axle)............Larger (1-1/2T and up) trucks have a "barrel" type bearing that is often mistaken for a tapered roller bearing. Sadly, it is not.
*** GMC ***
#26481 05/08/2004 3:00 AM
I looked in the '29-'54 Parts Catalog, and the 3/4 ton bearings are different sizes than the 1/2 ton.
#26482 05/08/2004 4:47 AM
Yes, You are correct, sir. But they are Ball bearings none the less........... eek
*** GMC ***
