0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26354 11/21/2003 6:08 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I have installed a flex fan on my 261 and I don't know how much a flex fan flexes? In other words, how much clearence should there be between the fan blade and the harmonic balancer?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#26355 11/21/2003 6:27 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | The fan will flex foward as it pulls air.If it clears when the engine isn't running, you'll be fine. | | |
#26356 11/22/2003 1:18 AM | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | I have a 16" Flex-A-Lite on a '56 235, in my '49. The clearence is about an inch or less, I go 70-75 all the time, no damage.
One thing you could do to ensure the distance remains constant is to make sure your engine mounts are in good shape.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#26357 11/23/2003 11:03 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Is 1/8" enough room to go with? Thanks!
#26358 11/24/2003 9:31 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've got to ask again, is 1/8" enough room to go with on the distance between the fan and the harmonic balancer? Thanks!
#26359 11/24/2003 10:42 PM | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | What year truck do you have? What year 261 do you have? How are your engine mounts? Do you have the shorty water pump sold by Patrick's? Are you trying to run the stock fan? I wouldn't be comfortable with 1/8" clearance.
The engine mounts are a steel-rubber sandwich and are made to flex and dampen torque and vibration. IMHO, 1/8" is too little.
#26360 11/25/2003 6:19 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | My truck is a 37 1/2 ton pick up with a 56 261 in it. The front mount is the standard older truck front mount, on the cross member under the timing cover. The rear mounts are on the bell housing. I have the short shaft water pump sold by Patrick's and others. I bought mine from [censored] Larrowe. I've got a 15" Derale Flex Fan mounted with a 1/2" spacer. I have another spacer that is 1/8" I can add if I have to. That spacer would put my fan about 1/4" away the harmonic balancer and about 1/2" or slightly less away from the radiator. Even when the 216 cu. in. engine was in my truck, I was working with no more than 5/8" from the stock fan to the radiator. It's very cozy in there!
#26361 11/25/2003 7:15 AM | Joined: Sep 2002 Posts: 49 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 49 | here is what i remember on my 327... a flex fan (at least the one i used) is meant to pull less air at higher rpms - that means that it will flatten out -->i.e. the blades (or ramps) will not be as 'steep'. (air molecules act like the dukes of hazzard and like to jump off of ramps, propelled in the direction and angle that they are pushed) that means that the outside edge of the BLADES will pull forward slightly at higher rpm. so if it clears the motor and associated parts behind the fan while not running - you are ok.
Build 'em to Drive 'em
#26362 11/25/2003 8:01 AM | Joined: Oct 2003 Posts: 38 Member | | Member Joined: Oct 2003 Posts: 38 | How about a 1 or a 2 inch spacer between the pulley and the fan?
Be Happy and Live a Good life filled with Love and Happiness.
#26363 11/25/2003 6:14 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | 6cylinders: If your Derale fan is anything like mine, it's not going to flex very much. Mine has some really stiff blades. They won't even flex when you push on them by hand. I don't have anymore room than you have described and have had no problems. Seems like it should work just fine. Good Luck George | | |
#26364 11/26/2003 7:30 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Thanks, George! That was the last thing I had to work out and I guess I should have asked you first. Sorry! Happy Thanksgiving!
