| | | Forums66 Topics128,108 Posts1,056,567 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26149 12/16/2001 2:46 AM | Joined: Dec 2001 Posts: 14 Member | | Member Joined: Dec 2001 Posts: 14 | I am getting ready to change out the tranny on my 54', the old tranny is junk. So when I put the new one on what do I need to lube up, and with what? If the throwout bearing looks good do I need a new one/ the clutch is relatively new with <1000 miles on it, same with engine. I was also going to buy the driveline bushing and seals from ChevyDuty, is that a good idea? I was also thinking about a new U-Joint from ChevyDuty, kind of spendy but does anyone know where to get them? Do any of the major parts houses carry the U joint assemblies? Help and thanks in advance!!! :p
rje
#26150 12/17/2001 11:26 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | RJE,
Pre-lube all the gears and bearings, particularly the rear output shaft bushing! This is the bushing that the front u-joint yoke rides in.
You could use gear oil, but STP assembly lube is also good.
The throw-out bearing itself is a sealed, permanently lubed thing.
A light coating of grease on the front bearing support "snout", the splined part of the input shaft, and the pilot bearing surface will complete your pre-lube.
As far as I know, u-joints for torque-tube drive lines are not available through regular jobbers such as Neapco; they are from folks like Chevy-Duty or Jim Carter only. Sorry!
Don't forget to lube that rear bushing! I didn't, and "wiped it out" with in 50 miles!
Frank
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
