1 members (Gray_Ghost), 87 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#26149 12/16/2001 2:46 AM
I am getting ready to change out the tranny on my 54', the old tranny is junk. So when I put the new one on what do I need to lube up, and with what? If the throwout bearing looks good do I need a new one/ the clutch is relatively new with <1000 miles on it, same with engine. I was also going to buy the driveline bushing and seals from ChevyDuty, is that a good idea? I was also thinking about a new U-Joint from ChevyDuty, kind of spendy but does anyone know where to get them? Do any of the major parts houses carry the U joint assemblies? Help and thanks in advance!!! :p
rje
#26150 12/17/2001 11:26 PM
RJE,
Pre-lube all the gears and bearings, particularly the rear output shaft bushing!
This is the bushing that the front u-joint yoke rides in.
You could use gear oil, but STP assembly lube is also good.
The throw-out bearing itself is a sealed, permanently lubed thing.
A light coating of grease on the front bearing support "snout", the splined part of the input shaft, and the pilot bearing surface will complete your pre-lube.
As far as I know, u-joints for torque-tube drive lines are not available through regular jobbers such as Neapco; they are from folks like Chevy-Duty or Jim Carter only. Sorry!
Don't forget to lube that rear bushing! I didn't, and "wiped it out" with in 50 miles!
Frank
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
