7 members (HandyAndy, 68ironhead, Rexville48, walter74, 6inarow, GMCJammer51, 1 invisible), 80 guests, and 1 robot.
Topics128,035
Posts1,055,567
#25412 12/16/2002 6:03 AM
found a old inline 6 engine in the bone pile .It has no head (blind block) no valve cover external push rods shaft driven waterpump distriputer sp and starter generater.It is hooked to a bell housing that has a cluth with many disks
#25413 12/16/2002 6:08 AM
need to find out the history and make need help
Thanks jess rotten
#25414 12/17/2002 1:29 AM
can you find any casting numbers? or post a picture?
Paint & Body Shop moderator
#25415 12/17/2002 6:10 PM
Send us the casting numbers and we can tell you what you've got. I'd also look it over very carefully for cracks and any rust that might indicate a crack you can't see with the naked eye.As a preliminary step, this is important. If you end up getting it, you're going to want to have it checked over and probably have it magnifluxed and checked out internally in addition to planing the surface where the head mates. Take a look at the cylinder walls as well.
#25416 12/26/2002 9:57 AM
I am still waiting to hear more about this engine find cool
