1 members (walterhvogel),
87
Mod | | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25412 12/16/2002 6:03 AM | Joined: Dec 2002 Posts: 7 Member | | Member Joined: Dec 2002 Posts: 7 | found a old inline 6 engine in the bone pile .It has no head (blind block) no valve cover external push rods shaft driven waterpump distriputer sp and starter generater.It is hooked to a bell housing that has a cluth with many disks | | |
#25413 12/16/2002 6:08 AM | Joined: Dec 2002 Posts: 7 Member | | Member Joined: Dec 2002 Posts: 7 | need to find out the history and make need help Thanks jess rotten | | |
#25414 12/17/2002 1:29 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | can you find any casting numbers? or post a picture?
#25415 12/17/2002 6:10 PM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Send us the casting numbers and we can tell you what you've got. I'd also look it over very carefully for cracks and any rust that might indicate a crack you can't see with the naked eye.As a preliminary step, this is important. If you end up getting it, you're going to want to have it checked over and probably have it magnifluxed and checked out internally in addition to planing the surface where the head mates. Take a look at the cylinder walls as well. | | |
#25416 12/26/2002 9:57 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I am still waiting to hear more about this engine find
