Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Phak1, Hotrod Lincoln, DoubleB), 154 guests, and 4 robots.
Topics128,284
Posts1,058,526
Members48,490
#25257 05/17/2005 4:45 AM
Junior Member
Junior Member
Hey everyone~ I just spent the last 7 hours under my 36 chevy making the cross member that is going to hold that tailshaft of the TH-350 that is mated to a chevy 305 V8. I figured now would be a good time to pull the master cylinder and make new lines.... a previous owner of the truck already got into this thing and changed alot of things around, I feel that might be the case with this MC. the only numbers I can find left on the MC is "A1382" does anybody know where / what this thing came out of. it's an old cast piece with the pivot point for the brake peddle built into the unit... it has only one brake line going to it that exits directly rear of the MC. please help ~Mykk
#25258 05/17/2005 5:03 AM
sounds like the usual MC on any old GM - can you post a picture of it?
#25259 05/18/2005 4:57 AM
Junior Member
Junior Member
Ya know, I took care of it... I took the unit down to the auto parts store I used to work at and matched it up using pictures in the brake parts illustared guide... I got a rebuild kit and it's done... thanks for the help though
