| | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#24894 05/12/2002 11:30 PM | Joined: Feb 2002 Posts: 15 Member | | Member Joined: Feb 2002 Posts: 15 | The cowl drain tube (from the cowl vent below the windshield) on my '47 truck has about a 1 foot long tube that empties right on top of the valve cover. I never thought much of it until I realized that the valve cover on this truck has three small slits that vent it. Never noticed them before because they point aft. This valve cover (on the 216 motor) isn't one with the vent/oil add pipe that sticks up from the cover. So....does anyone know what the original configuration was? The cowl drain ends right over one of the three vent slits. Bummer. Thanks. | | |
#24895 05/12/2002 11:40 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Well , dumb as it may seem , , what you have is how it was . I was thinking about this the other day , I think I will extend the drain with a tube down to the bell housing area , or somewhere near there . | | |
#24896 05/13/2002 8:15 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Some will re-plumb with 1/2" copper tubing followed by some paint to blend it in with the firewall.
Fred 52 3600 69 C-10
#24897 05/14/2002 2:15 AM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | How else does the valve cover get cleaned? | | |
#24898 05/14/2002 5:33 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Yeah, and has been dumping rainwater on and in to my starter :mad: . Also makes for a paint-free valve cover with a light rust coating.......... :rolleyes:
*** GMC ***
#24899 05/15/2002 1:15 AM | Joined: Feb 2002 Posts: 15 Member | | Member Joined: Feb 2002 Posts: 15 | I guess this is why they called this model truck the "Advanced Design". Thanks for the input. | | |
#24900 05/15/2002 3:46 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Or in my case a "New Design" :rolleyes:
*** GMC ***
#24901 05/15/2002 4:17 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you drive often in the rain with the vent open?
Does your vent gasket seal when the vent is closed?
Maybe a short-term and partial solution is to direct the drainage tube to the other side of the block (the intake/exhaust manifold side). I thought that this is how it was supposed to be directed.
Next, connect an extension tube, long enough to reach the bottom of the block.
I have never had this problem with my trucks - just lucky, I guess. My drainage tubes are pointing to 4 o'clock (when looking from the front of the truck). Tim | | |
