0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 21 Junior Member | | Junior Member Joined: Aug 2007 Posts: 21 | Is that handle the same as the 47-51 cab door handle? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Well,,yes and no. If you use only the handle,its the same.(i did it on my 54 panel) You have to use the flat base from the panel truck handle...... So,,it takes a bit of imagineering. It involves taking apart the pickup door handle,,and switching the flat base(panel truck)/beveled base(pick up). Then youre only rechroming the little base piece. I know,,,lotta hassle,,,but it works. Marty | | | | | Joined: Aug 2007 Posts: 21 Junior Member | | Junior Member Joined: Aug 2007 Posts: 21 | So, then if my handle sags like most do, a new handle will fix this because I can use the guts and handle from the one but the old base? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I think the guts are different.
The sag is usually a spring inside that I've read is not the same as the spring in the doors.
On mine some of the sag was a worn square hole in the guts, and swaping that with another fixed some of the sag, but not the spring part. I'm wondering if a spring shop can make new ones, but I've not asked.
I should ask, because two of my brothers work at places that make springs...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | No,,,I was just referring to the handle itself. The innards is a whole different story. Marty | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The length of the post on the handle (and where the spring/lock attaches to the post) is different for different years of panel-door handles. You will need a handle with a post that matches the escutcheon that you plan to use. If you use your panel escutcheon with a side door handle, there is no guarantee that they will work.
However, most vendors will let you send back a part. Buy one for a side door. Send it back if it does not work and let us know if it works. Actually, the cost of shipping is so high that, if it does not work, you might as well keep it and sell it at a swap meet. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | On my panel, the rear door handle has made a crescent shaped mark on the door. The handle is just rubbing on the door and now that it is almost ready for paint, I'm wondering how to avoid this problem. I'd appreciate any input. | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Leo, I had the same problem on my panel with the handle rubbing the door. I couldn't see any type of adjustment that I could do to keep the handle from rubbing the new paint, What I ended up doing was taking the handle off the door and grinding just a little off the end to give it room to swing with out hitting the door. I know that wasn't the proper way to address that problem but it was the only solution I could find. Maybe someone will kick in and tell us what the real problem is with the handle.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Originally posted by 1953 panel: On my panel, the rear door handle has made a crescent shaped mark on the door. The handle is just rubbing on the door and now that it is almost ready for paint, I'm wondering how to avoid this problem. I'd appreciate any input. These door handles had rubber gaskets. See if yours is worn or missing. Add a second gasket and see if that helps. The handle may be worn out and needs replacement. I know that passenger door handles can be modified to work, just reuse the rear door bezel and modify the shank as noted in the previous posts. | | | | | Joined: Aug 2007 Posts: 21 Junior Member | | Junior Member Joined: Aug 2007 Posts: 21 | | | | | | Joined: Apr 2004 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 34 | The door handle on the barn doors for panels and subs was apparently a unique item, even though it LOOKS the same as the front door handles. Finding a good used one is pretty much impossible, I tired a few years back, but found the local chrome-plating shop (restoration stuff, not bumper grade) could fill in the pits and rechrome the handle for less than a new side-door one! I used Cambridge Chrome here in Ontario, Canada, www.custom-chrome.com ... they have a US address you can ship to. The reason these handles sag is wear on both the square post of the handle and the square hole in the latch mechanism. Get your plating shop to rebuild the square post on the handle part ... I made a bushing to fit in the latch part to make it "square" again. | | |
