1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#247024 04/27/2007 3:19 AM
What's the weight of my 59 Suburban?
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#247025 04/27/2007 5:03 AM
You should be able to take it to any rock quarry or trucking outfit and theyll weigh it for you. They usually charge 10.00 if its for a D.M.V. required weight cert.(where they have to fill out paperwork)
If you just want a quick weigh job they might do it for nothing,,,especially if they like your truck.......
Marty
#247026 04/27/2007 2:34 PM
I've weighed car/trailer at a Mover's Warehouse ie. Mayflower, United, Beakins.
#247027 04/27/2007 11:55 PM
Leo Offline
Moderator
Moderator
Out our way, whenever you bring stuff to the dump, they weigh you in and out and you pay only for the garbage you left at the dump.
#247028 04/28/2007 1:50 AM
On the highway, when the truck scales are closed (no officers), they leave the scales on so truckers can check axle weights if they wish. I've done same with pick-up loads, etc.
Royzell
#247029 04/28/2007 3:06 AM
I was hoping someone would know the factory listed kerb weight. I don't drive it enough to get anywhere near interstate scales.
More on Hotrodders
#247030 04/28/2007 5:01 AM
Your local feed store probably has a scale, at least they used to weigh the hay as it came in.
#247031 04/28/2007 11:16 AM
Apprentice
Apprentice
The folks that recycle generally have one too.
Good luck. smile
"There are no shortcuts to any place worth going"; Anon....
