0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | What's the weight of my 59 Suburban? | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | You should be able to take it to any rock quarry or trucking outfit and theyll weigh it for you. They usually charge 10.00 if its for a D.M.V. required weight cert.(where they have to fill out paperwork) If you just want a quick weigh job they might do it for nothing,,,especially if they like your truck....... Marty | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | I've weighed car/trailer at a Mover's Warehouse ie. Mayflower, United, Beakins. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Out our way, whenever you bring stuff to the dump, they weigh you in and out and you pay only for the garbage you left at the dump. | | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | On the highway, when the truck scales are closed (no officers), they leave the scales on so truckers can check axle weights if they wish. I've done same with pick-up loads, etc.
Royzell | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I was hoping someone would know the factory listed kerb weight. I don't drive it enough to get anywhere near interstate scales. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Your local feed store probably has a scale, at least they used to weigh the hay as it came in. | | | | | Joined: Dec 2006 Posts: 16 Apprentice | | Apprentice Joined: Dec 2006 Posts: 16 | The folks that recycle generally have one too. Good luck.
"There are no shortcuts to any place worth going"; Anon....
