1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#246169 10/24/2006 3:47 PM
Is there a plate that lists the body # and
paint code on the 54'Sub/Canopy Ex. ??
Where is it located ??
chnaus
#246170 10/24/2006 5:01 PM
chnaus,
The Chevrolet truck vehicle ID plate is on the driver's side door hinge post, between the hinges (held in with 2 rivets).
If you post the code here, someone will decode it.
There is no paint code anywhere on a 1954 Chevrolet truck.
Tim
#246171 10/27/2006 3:51 AM
The ID is L54T016958 .
The registration apparently has the
engine # which is 0205646-T54UB.
Any help decoding is appreciated.
Thanks.
chnaus
#246172 10/27/2006 10:25 PM
L54T016958 (Vehicle Identification Number)
L = 3800 series truck (1-ton)
54 = 1954 (model year)
T = Tarrytown, NY (location of assembly plant)
16958 = production number (16958-1000 = 15958th truck built that model year)
0205646-T54UB (engine ID: engine "serial number")
0205646 = 204646th engine built (this seems high?)
T - Tonawanda (location where built)
U = 235 6-cylinder engine, 112 horse-power, 1-barrel carburetor, Heavy Duty transmission (I do not know if this meant 3-speed and/or 4-speed)
B = 3800 series truck (1-ton)
