10 members (JW51, Tinker5, TUTS 59, wilbur53, 3B, jupitor, GMCJammer51, J Lucas, walter74, dt235sd),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 19 New Guy | | New Guy Joined: Oct 2006 Posts: 19 | Is there a plate that lists the body # and paint code on the 54'Sub/Canopy Ex. ?? Where is it located ?? chnaus | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | chnaus,
The Chevrolet truck vehicle ID plate is on the driver's side door hinge post, between the hinges (held in with 2 rivets).
If you post the code here, someone will decode it.
There is no paint code anywhere on a 1954 Chevrolet truck.
Tim | | | | | Joined: Oct 2006 Posts: 19 New Guy | | New Guy Joined: Oct 2006 Posts: 19 | The ID is L54T016958 . The registration apparently has the engine # which is 0205646-T54UB. Any help decoding is appreciated. Thanks. chnaus | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | L54T016958 (Vehicle Identification Number) L = 3800 series truck (1-ton) 54 = 1954 (model year) T = Tarrytown, NY (location of assembly plant) 16958 = production number (16958-1000 = 15958th truck built that model year)
0205646-T54UB (engine ID: engine "serial number") 0205646 = 204646th engine built (this seems high?) T - Tonawanda (location where built) 54 = 1954 (model year) U = 235 6-cylinder engine, 112 horse-power, 1-barrel carburetor, Heavy Duty transmission (I do not know if this meant 3-speed and/or 4-speed) B = 3800 series truck (1-ton) | | |
