1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#245709 06/24/2006 1:51 AM
Apprentice
Apprentice
Bought a '50 Chevy 3800 panel truck for $1500. on ebay assembled in Norwood OH!! No garage, few if any tools, gravel parking, Chevy parts guy...not a mechanic and somehow, I'm making it happen. Low buck modifications are necessary 'cause parts guys aren't rich. Any ideas for low buck power steering conversion and power brakes. I found 1978 Chevy C-20 8-lug 16.5X6 rims and Firestone Transforce 950 16.5 tires look to be a close match and fit. 1967 C-20 differential case with 4.11 gear that should bolt in, so I've been told. And losts of shopping between different parts suppliers pays off. I have a 250 and 400 turbo trans. Many say that's a great combo, some say not. Any thoughts most appreciated. Thanks, Steve [IMG]http://C:\Documents and Settings\Steve\My Documents\Truck[/IMG]
#245710 06/24/2006 1:54 AM
Apprentice
Apprentice
Forgot to mention computer ignorance as one weakness, I'll wait 'till a kid or my little woman can show me how to post pictures.
#245711 07/12/2006 4:25 AM
If you'll go to Photobucket.com you can set up an account to 'host' your photos, then post them here.
#245712 07/28/2006 10:22 PM
I am planning on updating a '48 panel. I got a '74 suburban for $800. It's got all I need. Front end steering/suspension, rearend, transmission/engine, steering column. I thought it would be cheaper than buying all those parts separately. I also needed a truck to tow the panel home, so I know it all works. Now I need to set up an overhead I-beam w/trolley-hoist since I don't have a slab to work on. I'll post pictures asap.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
#245713 07/29/2006 1:12 AM
Walter, welcome to the Stovebolt! I must have missed your first few posts, but I always like to jump in and say hi to new locals...
Is your panel a 3100 or 3800? And what size is your Suburban, 1/2-, 3/4- or 1-ton?
I have a 3800 and a bare 1-ton frame sitting out back, and a '72 3/4-ton frame. I'd love to come by and watch your project go together. Where are you?
For completeness I should say I also have three 1/2-ton Suburbans/panels also. I seem to be addicted.
#245714 09/23/2007 10:08 PM
It's been awhile. My panel is still sitting. The 1/2 ton suburban is resting too. The front end is about 1/2" wider than the panel frame. I thought I could just add some shims to make it fit. does anyone have any suggestions for a front end that's a match?
In Project Journals
In the DITY Gallery
#245715 09/24/2007 4:02 AM
1 Offline
seems like 47'-54' panels and burbs are too narrow for those front ends. i have measured dozens of 73'-87' chevy trucks hoping to use one and after checking s-10 and 78'-85' gm car they seem to be better suited. my 54' burb will have dropped axle,pdb,toyota 4x4 ps. my 52' panel will be going on s-10 running gear.good luck on your project.
#245716 09/24/2007 4:56 AM
Anonymous
Unregistered
Anonymous
Unregistered
Many folks have put the 70's & 80's truck suspension under their truck & like it. The only problem I have seen is the tires stick outside the fender about 1-2inches. You might be able take care of this problem by using narrow rims &/or shortened upper & lowwer control arms.
Also Chassis Engineering has a bolt in M2 kit for the trucks.
