8 members (carbking, Gdads51, Wally / Montana, klhansen, NJC, 2-Ton, 55shaker, Joe H),
46
Mod | | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 7 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 7 | I have a 1939 GMC 1/2 ton Panel Truck with 2 sets of bumpers. One set has two small groves across the blade and the other set has one wider single grove approximately 7/8. Problem? Which set belongs on this truck? They both appear to be similar in length and shape and bolt up to the same brackets. And? Are panel and pick-up bumpers the same? THANKS for your input, Nick | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Can't say for sure Nick but i think the one with 2 grooves is for a '40. I've been looking for a '40 panel rear bumbper for my pickup for a long time. If that isn't the one you wind up using please let me know. Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Here is one on ebay claiming the single groove is for a '39. Item number: 4633224165
40 Chevy 1/2 ton
| | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | NICK; I HAVE A 1939 CHEV SUBURBAN AND THE PROPER BUMPERS HAVE THE 1 INCH WIDE GROOVE WHICH WAS PAINTED BLACK. I WOULD GUESS THE SAME BUMPER WAS USED ON GMC TRUCKS AS WELL.
STAN NORRISH | | |
